First thing that u need to do is study this:
http://www.batteryfaq.org/
Of course, my system is diff than others:
http://homepage.mac.com/dfmorse/BattProj2/page1.html
My system uses the HellRoaring battery split and charge system.
My back-up batt is allways at 12.6+ volts.. Keep this in mind...
http://www.hellroaring.com/bic75300.htm
I have been dealing with this drain problem for at least 5 years on my 94-FZJ80; and have no real answers; except to say that the alternator will not EVER charge the battery to 12.6 volts; that is with the AGM batteries I am using.
First; u need pencil and paper at ur side.
Engine off:
Record the voltage on the battery terminals. ( I will assume u know how to do this).
Start the engine;
The engine is running at around (cold) 1200rpm. The voltage across the battery should be close to 14.22 volts. It can be as high 15.77 volts; but , will slowly drop as the battery charges. A fully charged battery {WRT the alternator] will show a round 14.00 (mine reads around 13.97 volts). Keep in mind that I monitor current and voltage 24/7; my websitite shows this. My system is not available on modern vehicles.
Bottom line is something like this. The Alternator will never charge the battery to full charge; especially when u go to a OPTIMA/ODSESSY high teck batteries. What this means is this :
U need to pull the battery and charge it on a Proper charger. Do this about every 6 months.
The original FZJ80 (USA spec) was furnished with the Panasonic battery, witched matched the alternator output algorithms. New high tech batteries do not match the algorithms of 1994 alternators (The alternators are 1 or 2 step systems only; the battery requires a 3 step system).
If u read all the stuff in the batteryFAQ, one will find that this is a never ending problem.
SOLUTION:
An alternator that will charge the battery to "Battery Factory" specs.
What I do is pull my batts around 6 month and put them on
the right charger.
The primary ECU that runs the FZJ80 draws around 15ma of current + the clock and stuff. A low charged High teck batt left in this state will discharge to below 11.0 volts. The voltage required to fire and run the ignition is right at 10.5 volts (USA SPEC); will crank the engine , but not necessary fire it...
Enough
David in Denver
k0dar
