I haven't searched here yet or thoroughly looked at my wiring yet. I used the 40 to winch my 80 behind the gate and will look in the morning when I have light.
I went to start the 80 to put it away and it began to crank and then CLICK nothing. No headlights either. I check the battery and the fuses in the engine bay and everything looks good. Well then I decided to use the winch and put it away...hmmm the winch doesn't work. I touch the negative post on the battery and negative connector around the post with a wrench and I get sparks AND the interior lights go on and off as I do this because the driver door is open.
I am assuming I am getting positive current to the negative ground wire going to the battery causing this situation (winch negative is tied to this as well). I don't know why I would be or how but I will look into it tomorrow with hopefully some help from you all.
TIA
Garett
TIA
Garett
