Electric window problems
Oregon
Website
www.brian894x4.com
My driver's side electric window (95 FZJ80) started having problems rolling up and getting stuck. After searching, it seems the most common problem was worn window runs. I pulled everything apart, cleaned the runs as best I could. But they looked to be in good shape (rig only has 94K miles on it). I couldn't find any other issues, but the problem persisted intermittently.
Now, something broke, but I can't figure out what. It sounds like the window motor gears are stripping and the motor makes a loud buzzing noise (like gears out of mesh or something) when I try to roll up the window, including when the window is all the way up.
I'm about to order a bunch of other parts from Cdan and would like to just order whatever I need to fix this window. Anyone have a idea of what I might need, from any prior experience with the same problem, noise, etc? (new gears? motor?)
B -
My driver's side electric window (95 FZJ80) started having problems rolling up and getting stuck... I couldn't find any other issues, but the problem persisted intermittently.
Did you find that after getting stuck, if you left it be for awhile the window could be moved a bit more... and so on?
I had a very similar problem on our Corolla, and traced it to a bad winding on the motor, which was heating up due to excessive resistance, dropping the voltage, and stalling the motor. Ending up replacing it. (FYI, LH door & RH door motors are not interchangeable.)
>> Now, something broke, but I can't figure out what...
Sounds like a separate problem, or perhaps the motor has given up completely. You really need to take it all apart and see what's going on in there.
R -
OK, I'm changing my entire message around, because I was able to rip everything out and take a closer look. I was a bit intimidated at taking out the window, motor and mechanism, but thanks to some of the threads, it was much easier than I thought.
The regulator/sliders all look good, except for the top slider, which seems looser than it should be, but the plastic ball appears to be spring loaded, so maybe this is normal. The runs could probably definately use replacing and that might be my binding issue. Also, now that I see how the sliders are adjusted, that might have been out of adjustment too.
However, I've got one major issue and that is what appears to be stripped gears inside the motor. The metal regulator gear is fine and the big gear outside the motor is fine, but very loose. When I pry the cap off and look inside the motor gearing, the plastic gear looks like its stripped.
What happens is the motor has enough power to push the window down but when going up, it hesitates in a spot and then clicks, like the large plastic gear has a worn spot. Without tearing into it further I can't confirm this, but I'm pretty this is what's going on.
So, I guess I need a new motor. But what I'm wondering is if Toyota used the same motor on all four windows? If so, I'll just pull one from the back window I don't use, instead of ordering a whole new motor. Can anyone confirm this or are the motors different front to rear or side to side?
If that motor is unique to that door, I'll probably just order a new one from Dan, but hoping I don't have too.
Brian -
The part numbers for all four window motors are different on our Corolla, as well as on the Cruiser. I vaguely recall Dan confirming this when I got my new motor from him... but that was years ago. It wouldn't hurt to confirm that before tearing another door apart.
Good luck!
R -
I fixed my problem. I took a few pictures, so I'll do a write up about it later.
After taking everything apart, I found that the window tracks were most likely out of adjustment, which caused the window to bind and eventually the internal gearing in the motor to fail.
All of the gears in the power window system are metal except for one. There's a large dial gear inside the motor and its plastic. It's most likely a designed failure point.
Once I fixed the track, I needed to do something about the motor. A new motor is about $300. I pulled the motor out of the driver's side rear door, hoping that it would be the same part. It's not. It's nearly indentical, except that it's reversed and won't bolt up to the front door regulator. The plug is slightly different too. However, the internal gearing mechanism is all the same.
So, to make a long story short, I swapped internal gears of both motors. Now the front motor works perfectly. The rear window is now permanantly rolled up and the motor disabled, just so I don't accidently roll it down. That passenger seat has been removed for storage, so not being able roll down that window is no big deal at all.
Removing the gears required removing the motors from the regulators, prying off the gear cover, undoing a C-clip and just swapping the internal gears. Simple really.
A couple things I found doing this swap. In several past threads, there's been some comments about the outside motor small gear being loose and this being normal. It's not normal at all. And in fact, I think this is the root cause of most of the power window failures.
What happens is the C-clip that holds the motor gearing together fails and everything loosens up. On mine, water got in somehow and caused the metal parts, including the C-clip to rust to the point of failing. The gear shaft is suppose to fit in a tight rectangular hole, but that hole gets rounded over time and the whole thing is loose. Eventually it gets out of alignment and something is going to fail. Either the motor will sieze up or the plastic gear will strip. I'll bet this the primary cause for the slow and jerky roll up some people experience.
It's too bad you can't purchase these parts seperately. All you need is a few gear parts, but instead you either have to cannabolize one of your other motors or replace the entire motor at almost $300 cost.
Interestingly, the rear motor gearing looked brand new, like it was made yesterday. Why water got into the front driver's side and not the rear is a mystery, but this seems to be a common problem. I'm guessing the extra wear and tear on that particular motor and gearing, since its used the most, allows water to get past the seals and then it's downhill from there.
