electric seats
high desert, ca
My wife says the bench seat in the 55 goes, so bucket seats it is. The bucket seats I have looked at that I've liked are electric. Is this worth the hassle, or is it as simple as running an accessory wire to the seats? I'm not an idiot and can read wiring diagrams and such, but do not know the most about electronics (only enough to pass technical tests for verizon tech screening).
What brands have been used? Do most new vehicles have similar seat wiring design? I am looking at 2000-2005 seats, and am currently eyeing a real nice pair of tan leather ford explorer seats and also some new caddie seats.
I bought my Silverado seats for my FJ55 off of ebay. I was looking at heated leather all electric ones, but my wife made fun of it. It was basically, "Is this a luxury vehicle or a rugged outdoor cruiser?" I got all manual cloth ones :grinpimp: As far as I know, all the electrics are withing the seats, you provide power and a ground.
true
If you don't have a heater, then just supply power and ground. Give it a good 20A source. If you do have a heater in the seats, you will want it accessory switched so if you forget to shut them off when leaving the rig, it wont drain the battery or burn up the heating element
I have buckets out of later Camaro all the electronics are in the seat just a power and ground ia all that is needed from the battery so you can adjust without turning the key on
I also have seat heaters but thats hooked through a relay off an acc circuit
Thanks, that is what I was looking for. I never got a chance to look the wiring on the seats. I do not give a rat's ass about heated seats. I would rather have manual adjustments, but the seats I have liked happen to be electric. I am choosing a seat for looks and comfort, and if it happens to be electric, it is going in anyways. The explorer seats were really pimp, but were $400, the caddie seats were $200.
So I finally found some seats from a 2003 CTS. I am only using the power part, no heater and no side airbags (removed already).
So since I am an electrical dummie, set me straight. Do I just hook up a relay to my ignition and tap the main power from the battery? A fuse goes between the relay and the battery, correct?
What amperage fuse is needed for something like this, 20A, 30A?
Is 12g wire sufficient?
