Electric problem
Sweden
Hi I have a hj60 2h 24volt 1989 landcruiser. I have take everything apart and now put it tougheter. Now it wont start. I have electricity to starter and relays work. Inside cab I have electricity to hazard light and high beam. Nothing more. If I hot wire The starter The engine cranks but with key nothing. I have extra grounds for engine. Body and frame.
What can I check? Relays? Kind regards
What is "everything" that you took apart? Off the top of my head, I would check the fusible links on the high side battery. If they were disturbed as part of "everything", they may have been broken.
I dissmantle The hole car and put it tougheter. Now I do electricity system and have The problem. The car does not have fusible links
