Electric FJ40
12 years later, is this idea any more sensible?
13 years later. i'm considering it for my upcoming FJ60 restoration and have done a lot of research. Technically it is not difficult, it is not cheap. So I'm now weighing the cost/benefit ratio. There is a mining company in Australia that converted a bunch of older LC's to electric. Their reasoning was that only a LC was up to the though job inside the mines, but they needed to get rid of the exhaust fumes. So electric it became. They have not provided many details, but they have been using the trucks for a while now.
My situation is slightly different than for most LC owners:
- I live in a small town in Alaska where we don't have a road network. I live on one end outside of town and it is not possible for me to drive more than 30 miles round trip. The consequence of this is that the engine never properly warms up resulting in a lot of extra wear.
- Due to the tiny road network here I won't need a lot of range and can get away with a small enough battery pack that I can use standard lead acid batteries or AGM's without needing anything fancy (read: expensive).
- Maximum speed here is 40 mph so I don't need a lot of power either.
- I often need to pull heavy trailers (in excess of 5000 lbs) and that includes uphill. I'm truly pushing it with the 2F engine and the clutch really does not like that. I'd love a bunch more torque in the lower ranges.
- A diesel conversion would be the other alternative but is not cheap either, has less torque and is actually more work than converting to electric.
- We have hydro power here in town which is the cleanest energy you can get so it is the right thing to do for the environment.
- "Fuel" cost reduction is about 80% compared to the 2F engine.
The whole conversion would seems to cost about 15k in parts. that includes throttle control, chargers, controllers, batteries, wiring etc. Included in the price are additional electric pumps to drive the power steering etc. This is using new quality parts. I could probably stinch on that a bit and cut it in half by using salvaged parts. Not sure which route I would go and still not sure if I'm going to do it or not.
This funny guy on CL seems to have one. And a tailpipe.
Electric TLC FJ-40 Build
I'm sold on electrics but don't do a conversion thinking you are going to save money.
I totally agree that savings on money should not be the reason to do a conversion, but it greatly depends on where you live and how you use your rig if you can have any savings or not. Here in Sitka the difference is about 40ct a mile between gas and electric. If I do a low end conversion (used parts etc) I will break even at about 20k miles.
I thought an electric car would be cool when I first read about them in the 70's then in the 80's mother earth had an article about a guy making a hybrid out of an Opel GT and got me going again but it wasn't until Nov. 99 that I finally did a build.
I figured I would save a ton of money on gas and save the environment in the process.
I did save on gas, especially when it got up to four dollars a gallon.
After about ten years I was starting to see an ROI when I needed a new battery pack and that set me back to square one.
I just changed out for another new pack about eight months ago and even though the price of lithium has gone down a bit it still hurt.
Now the state has passed a bill that will charge me an extra $200 because it is electric when I go in to get new tags.
I really like the feel of an electric car so the extra $ will not deter me.
I had often thought about converting my 40 and seeing the ETLC has made me even more positive about it but unless that Somali Prince comes through with the cash he promised it will stay just a dream.
The other possible drawback could be the fact that I have driven the hunk of tin for 45 years with an ICE that I might not be able to adjust.
Even though I haven't saved big on an electric car it hasn't cost any more than an Ice when you factor in maintenance.
If you are pulling 5,000 pounds plus the 3,500 to 4,500 pounds of the vehicle I doubt you will be able to do a build that will move close to 10K lbs for $15,000.
Lead batteries FLA or AGM do not work well in cold weather. 70 degrees F is ideal temp and as the temperature drops so does the ability to give off power.
I am not saying they will not work just not well so you will need a way to warm the batteries in cold weather.
Lithium is not much better.
Also lead batteries probably will not meet the rate of discharge needed plus you will need some serious voltage and to get that you will need lots of them.
There are a lot of other factors pro an con.
You should go on DIY electric car forum and lay out your plans. There are plenty on people there that can give advice.
If engine warm up is your major problem you could get an engine warmer that you plug in at night.
The cost of electricity for a warmer per year would be way less than a conversion that is sure to put you in a budget over run.
Being in Alaska I am sure they are readily available.
I'm in South East Alaska, it barely ever freezes here (Average winter temperature of 36F) and the car is usually parked inside a heated garage.
I'm looking at 144V motors with a torque of about 250 ft-lbs at very low RPM. I only need a 30 mile range (we do not have more road here) and topspeed of 40 mph empty. When pulling a trailer I don't need any more speed than 20 mph. That significantly reduces the requirements on the electrical system.
As for the batteries, due to the very low range and low speeds that work for me, I can use an old Nissan Leaf battery that is at 80% capacity. You can buy those for about $800 and that gives you about 18 to 20kWh of energy. You can also buy a new one for about $3500. Those batteries are 400V and need regulators to work with the 144V motor.
