electric fan question
I'm stuck in the Texas heat and need to cool the Cruiser down a little more. I'm looking at the Toyota fan vs a cheaper one. I have searched but it pulls up alot of junk......Will any 14 inch fan fit behind the grill, is the Toyo fan that much better? and if Atoyot1031 sees this do you have any pics of you set up? Thanks
I installed a 12" fan out of a Camry? Got it at the pull a part for about 25 bucks. Wired it into the compressor power, a relay and an aux. fuze box. In my 92 this is the biggest I could go. This really made my AC work properly in the drive-thru's. The aux. fan mounted below the horns with no factory modifications. Today I installed 2 Grand Prix GTP hood vents to lower engine temps during these 100+ degree days.
I'll try and get pics up later tonite or tomorrow. I don't know if any 14" will fit, but I know the one I (and brotherob) installed will just barely. It puts out ~800cfm more than the OEM one and costs nearly $200 less. If you've seen my other posts about it, there is a link to it and the relay on ebay.
Here is a pic of my 12" Derale fan. A 14" fan would be a tight fit, and I doubt that all models would fit. The manufacturers' websites sometimes have overall dimensions that you could evaluate.
So, are you just looking for a supplemental push-fan for low speed city driving like at stop lights/drive thrus, etc?
Otherwise the ext mounted push fan might actually impede airflow on the highway.
Spal makes some great fans(pusher & pull) but they can get pricey...but their specs are usually dead-on.
SPAL USA
The 14" Derale just fits; IH8MUD Forums - View Single Post - Hotter than Hell in S Tex. - A/C Aux fan install ??!!
My experience is putting thicker fluid in the fan clutch has a greater effect. A pusher fan concentrates airflow in a relatively small area, actually reducing flow over the rest of the condenser. Improving the main fan improves airflow over the entire condenser, providing better overall cooling.
I have a universal 12 inch, that save me from overheating when the fan clutch went bad. Those new cost around 50-60 bucks.:popcorn:
Just to second what Tools has said, the stock fan can move a lot of air, with some mods. Per info that was posted by him, I added about 18 ml of 30,000 cst fluid to the factory fill of my new blue hub fan clutch and it made a huge difference. I went from overheating in traffic with the A/C off to being very happy with the air on and windows up.
14" Derale works perfectly!
Thanks for the replies guys....I'm going to look for the AutoZone fan and start there. One last question. I want to wire it direct to an always live switch. Any tips of what not to do, and will the stock alternator be fine with this?
... One last question. I want to wire it direct to an always live switch. Any tips of what not to do, and will the stock alternator be fine with this?
Just wire the relay trigger wire to a key on circuit, easy deal. The question would be why run it full time, it's not needed most of the time?
Someone did real data on this here on Mud awhile ago and found out that the fans WILL NOT impede any airflow at highway speeds.
Kevin, agreed if we were talking about a non-SC'd truck. I have 10k cst oil in my fan clutch with the 3.0 fan blade and modded shroud. With the 14" Derale running my water temperature difference is mucho significante! I do not have numbers, but I have a RT modded temp gauge and w/o the fan running (at offroad speeds), my temp will sit just below red. With the fan running, it will drop to the middle of the span.
That's my experience as well. I'd say between the modded fan clutch, 3.0 fan blade, hood vents, lower temp t-stat, med. pressure switched aux fan, the aux fan has made by far the biggest difference not just in AC temps, but water temps as well.
So can we buy a new clutch fan with 30,000 cst that will fit the 80 series. thanks, Mike
You would not want a clutch with 30,000 fluid in it, but by mixing 20 ml of 30k fluid with the 3k fluid that comes stock in a new blue hub clutch you end up around 10,000 cst. This has worked well for me.
Lots of good info has been posted by Tools R Us and others on changing the fluid in the stock fan clutch.
This is another option. Flex-a-lite P/N 394 (14in, 1530CFM).
