electric door locker gremlins
I just picked up a 96 lx450 and am working out the kinks.
Today the doors began to relock themselves. Here are some symptoms:
- With all doors closed and me outside vehicle, I press "unlock" on the remote. The doors unlock, and then immediately relock.
- From inside vehicle, press the unlock button on the door and the doors immediately relock
- I started the car to see if the problem would go away and it didn't
- While driving at various speeds (i.e. 40mph) the doors would sometimes lock
- from passenger front door, using key to unlock car, and the door would automatically relock
- Sometimes the key works to unlock the doors and they don't auto relock
- While driving the door ajar light sometimes flickers on and off, or stays lit
- Washed the car yesterday, and some water got past the sunroof seal and made a puddle by the driver footwell which I dried up
- The car starts and drivers fine
- I had the headliner out yesterday and reinstalled it. I disconnected the sunrood motor relay in the roof to prevent the sunroof from operating (a cable is broken). While diring the truck after the headliner was reinstalled I didn't notice any problems with the doors relocking.
Any ideas? Is it possible the door ajar is making the car think its being broken in to and relocking? On another board someone suggested checking the grounds. Is there an ECU for the door locks I can unplug to make the craziness go away?b
Had a similar experience this past fall. Doors would lock incessantly as the temp dropped overnight/early morning. The PO of the truck had installed an aftermarket Ultra remote starter/alarm system, which appeared to be the root of the problem - after contacting Ultra and going through all possible steps to troubleshoot and/or reset the unit didn't fix the problem, they diagnosed that something was wrong with the unit.
I unplugged it and problem was instantly fixed with no driveability issues, just have to unlock the vehicle manually now. I could see no signs of water in my unit, though I initially thought that could be the culprit due to the change in Temp/Humidity when the "gremlins" became most active...
With some digging, you should be able to find plenty of info in the forum regarding the factory lock/security system (if that's what you have in your rig, check under the driver's seat) and how to temporarily disable it to test without losing your ignition, etc...
Good luck.
