The problem with this is you need a few horsepower to drive an AC compressor. Now, roughly one horsepower is equal to 760 Watts. Lets say you need 2HP. that's just over 1500W. So, with some fancy dancy ohms law math we can convert that to Amps. 1500W/12V = 125A. So this would mean that whenever you wanted to run your AC your alt/battery would have to supply 125 amps over and above what you need for the rest of your vehicle. Now where does your alternator get its power... the engine. So, you now have to figure that to get an extra 125 amps out of an alternator, it is going to steal aproximately 1500W = aproximately 2HP from your running engine. This is not taking into concideration any system losses, friction or resistance!! Unfortunately, you can't get power for nothing!!
Which ever way you look at it, the power needs to come from the engine, unless you have some KICK ASS solar panels!!
The reason that the small coolers can run off your cigarette lighter is that they are cooling a MUCH smaller and MUCH better insulated area.
