EGR WTF?
flyinbrian
@brian_and_the_car
Santa Barbara, CA
So, I've replaced my EGR and EGR diaphragm, but I'm still getting the insuffiecient EGR flow code from time to time.
Do I need to...
1. replace all the rubber hoses too
2. replace the sensor, or override like all the threads have said
3. just run a higher octane fuel
I hate CEL's, but like to fix problems the right way. Any suggestions.
I recently had the same thing and it turned out to be the vsv. It is located underneath the intake manifold and can be a bear to get at. Not too bad with the resources available here. Do a search, there is a lot of information about how to go about fixing this.
-jim
Are you going through the diagnostics in the FSM - or just replacing parts as you see them?
Sounds like the VSV for EGR. Does your insufficient flow CEL come on after the truck has been running pretty warm for a while? Search for some of RavenTai's posts, he has a ton of info on the EGR system.
-jim
Not exactly a 5 minute job; but by taking the TB off, which is pretty simple you can get it off quite easily.
There is a method of doing it without removing the intake plenum. It involves a 3' socket extension and getting 1 bolt from underneath. The other bolt is removed by losening the bracket on the intake plenum, moving it to the side and getting it with a ratchet wrench. There are posts with more detail.
There is no sure fire culprit on this issue. This code is cause by one or more of the following (in no particular order):
  • VSV
  • Temp Sensor
  • EGR valve
  • Vacuum Modulator
  • Plugged EGR port from EGR valve to top of intake plenum
Check the easiest, cheapest item first; the EGR port. I know a fellow that worked at the local Lexus dealer for many years and he said this was so common it was the first stop in dealing with that code on LX450's.
I may be mistaken, but I don't remember anywhere that port is mentioned in the FSM and its diagnostics for this problem.
a simple test to see if your egr port in the intake is plugged would be to apply vacuum to the egr valve at idle.....if the engine dies, your port is clear.....if the engine only stumbles slightly or keeps running fine, your port is clogged. (behind the TB)
of course when you put vacuum to the egr valve T, plug the other side of the T with your finger or a plug to make sure you are getting full vacuum to it.
don't start replacing parts without at least trying this test.
tons of other egr info on here.
From my experience, the EGR valve itself is rarely the problem.
We recently had an "EGR Party" where I walked a few guys through testing the various components. They all had the same PO401 code (Insufficient Flow). In the end, they each had different bits that failed. One guy needed a VSV, another a VSV for EGR and the Vacuum Modulator, and the last guy needed all of those parts. :p + They all replaced the associated vacuum lines.
Unless money is no issue; Test the EGR system. Follow the procedures in the FSM and check for clogged ports/lines. Find out what is wrong and call CDan. Then say goodbye to your PO401.
Don't just toss parts at it hoping something will work and don't "band aid" the problem by bypassing or tricking the system. It is too easy not to fix.
