EGR Vacuum Values
Lonely Nevada
Website
www.willenosphotography.com
So I still have P0401 and have been thru the complete checkout by the way of the FSM. The only thing that has me raising an old grey eyebrow is the vacuum at port "P". Does anyone know what the vacuum is at 2500 RPM? "R" port is solid at constant throttle and falls upon closing the throttle. That part sounds good to me. However port "P" has NO vacuum until about 2100 RPM and at 2500 has about 2 in/hg.. where as the "R" port is a good solid 10+. In my mind it should have about the same value as "R" since they are almost siamesed since they are so close to each other.
Appears in a line drawing of the circuit that "R" is the front side of the throttle plate and "P" is just behind. My thought is both ports should have full vacuum when the throttle plate is open and "R" should have NO vacuum after the throttle plate is closed.
I am assuming that "P" is plugged. I have not been able to get a wire thru either port but I know "R" is clear. So without forcing the issue and causing a problem.. I would like to know if my vacuum theory is correct? If so.. I will proceed with clearing the brass tube a little more aggressively!! I really don't like to force anything until I have a clear picture. Nothing like having to fix something that YOU screw up because you didn't know what you were doing!!
Thanks!!
What I am looking to find out.. is there a restrictor in the "P" port on the throttle body? Hence the very limited vacuum compared to the "R" port.
