EGR Tube?
Kodiak, Ak
Hi guys,
I have what sounds like an exhaust leak (ticking) comming from the drivers side of the engine. I checked the exhaust manifolds as I assumed I crakced one of those and then I realized the sound was comming from the drivers side under the plenum. I was windering if there is an EGR tube that could have cracked. It is a 96'. Thanks I will have to pull it in the shop tonight and take a look.
Not much detail on what the sound is like/when it happens, etc but there are EGR system hoses on the DS that are easy to follow from the EGR valve at DS rear of the valve cover. Shouldn't be hard to locate if a vacuum or other line has come off with a bright light.
DougM
