EGR Testing Question for a noob
I hate to ask another EGR testing question, but the information I've seen has me somewhat confused on how to test the EGR. I have a 97 LC (120k miles) and am getting the P0401 CEL. I decided to trouble shoot the EGR and modulator (green cap) since these are easy access.
I removed the modulator, blew into the bottom port and could not feel air exiting any of the remaining ports. I also removed the cap and other than the filter being an off white color it appeared relatively carbon free. From what I understand, these tests would suggest the modulator is OK.
Then I tried to test the EGR. I connected a vacuum pump to the port that leads to the modulator and tried to draw vacuum. I could not get any vacuum and the vehicle remained at idle. I was under the impression that vacuum would be drawn and the vehicle would begin to stumble, however continue to run. In my case the vehicle idled just fine. Next, I left the vaccum pump connected to the port that leads to the modulator, then clamped the tube from the other port and while drawing vacuum the vehicle would stall. So, should I be able to draw vacuum without clamping the opposite tube or is vacuum only possible when the opposite port is effectively closed? If the latter, then it seems the EGR and modulator are OK, and I'm left with looking at the VSV, clogged tubing or dirty intake port.
Thanks in advance.
Do you have the FSM for your truck? If not, you should get one.
-B-
Final page of the Inspection section of the EGR System for your 1997.
-B-
Thanks Beowulf. I don't have the FSM and plan to order one. However, I'm trying to get a state inspection soon and don't think the FSM will arrive soon enough.
It is not uncommon for the VSV for EGR to fail on your 1997 at about your mileage. Mine and several others also failed. Raven's was intermittent and he has a detailed testing procedure for the VSV for EGR in one of his 'Mud threads. His testing procedure will help with intermittent failures. Mine was intermittent for about 9 months, then finally failed solid (i.e. failed the above resistance test.)
The VSV for EGR can easily be R&R'd without removing the intake (30 min job). The procedure has been described numerous times (5 to 10 times!) so search for the procedure before you yank the intake.
-B-
