As I'm still battling this Code 71 in my 94, I need a bit of clarification. When I performed the EGR test by applying vacuum to the valve at idle, the engine does indeed stumble but never dies. When I stop applying vacuum, everything returns to normal. Is the vacuum supposed to hold like a switch on this test? If so, a faulty EGR could be the source of my problem. Heaven knows I've replaced everything else (VSV, temp sensor, modulator, vacuum lines).
One other item that's pointing me in this direction is the fact that my engine pings frequently and my gas mileage has dropped from 14 to almost 10 and I have new O2 sensors. These same symptoms showed up a couple of years ago when I intentionally disconnected the EGR valve for awhile while doing some other testing.
