EGR System code 71
Redding, Ca
In typical fashion, I threw an engine code before I have to pass smog on my '92 3FE powered beast. Code 71. Two years ago I replaced the egr modulator that cured the same code back then. This time I tried a WAY better condition EGR (thanks again @LS1FJ40) but still popped the code. Tried the Dohrman VSV, my stock one was corroded and clearly not working. Threw the code. Checked the hard line between the VSV and EGR, not completely clogged, but enough to cause a problem. Bypassed the hard lines with new vacuum tubing. Threw the code.
Next step is to keep checking vacuum lines and hopefully cure the problem along the way. Does anybody know exactly what causes the code 71 to be thrown? I guess I could check my FSM.
Suggestions?
The ECU looks for a temperature change on the probe that indicates the EGR has opened up and is letting exhaust recirculate. If the probe never heats up after a time, the code will be set. You can short the wires on the probe connector to defeat the CEL!
Is that the Gyro Captain in your avatar?
Yep, short them out. That is how the factory did it for non-California trucks.
The pic is him from the Mad Max The Road Warrior movie.
Good to know. Malleus the Younger's 80 is a CA model.
I haven't jumped the temp sensor yet, but I decided to test it all out, I would prefer to have everything working properly for my smog test.
Tested voltage from the wires, good there. Pulled the temp sensor out, heated it up with a hair dryer while reading the resistance. Good there. Pulled out the FSM and began testing with a vacuum gauge. VSV appears to be working, zero vacuum while cold at 2500 rpm, small amount of vacuum at 2500 rpm when warm. But when I connected a hose from "R" on the modulator directly to the intake manifold, I should have had a high vacuum reading, gauge showed nothing.
Plugged the vacuum gauge directly to the intake manifold to see if maybe the small port was plugged, vacuum gauge showed great vacuum. So with deductive reasoning, my modulator is bad, correct?
I pulled the modulator off, opened it up and it still looks very new, there is a little bit of rust dust inside, I think residual stuff from the trucks life on the coast. Anyway, I hooked a hose up and tried blowing air through the different ports. Most allowed air to flow through except "R". Does this mean I need a new modulator? Is it supposed to not allow air through until a certain point?
Interesting there is red top, unless Im not paying attention, but thought there was a OG green top and then a blue top or visa vi.
Ok, ran all of the tests from the video, passed them all. The only test that it hasn't passed is the high vacuum at 2500 rpm when R is connected directly to intake. I guess I need to check all the hard lines, a couple have some bad corrosion.
I think you have a mistake R port (and P as well) on VM is connected in a direct line vacuum inlet on throttle body very near the P inlet. R is after and P before the position of the throttle at idle. They should show vacuum when the motor is running at any RPM and any temp including cold at the start.
The guy is checking them with a glove stuck to the metal tube in the video, that's it no need for more sophisticated measurements.
If P or R does not show Vacuum at when motor is running, then the easy fix some carb spray and gentle air should open the ports that are blocked
Check P and R vacuum before any thing else
If you have become in P and R good connect vacuum meter to Q on the VM and in 2500 RPM it should show vacuum when modulator will open with the assistance of pressure from the exhaust pushing the diaphragm. Modulator then is OK
Maybe this helps
Connect the Vac Meter to pipe from VSV to EGRV (marked RED) when motor hot and constant RPM below 3500 you should have vacume when VSV opens
I really hated testing this myself. It ended up being the VSV in my case and some clogged lines.
I had to completely remove the upper half of the intake manifold.
