I'll be changing the egr pipe, gasket, ferrule, and nut. I'll remove the cooler and pipe as a unit making it easier to separate the two outside the rig.
Before re-installing, I'll connect the two together, but once in, I expect the greatest difficulty will be in tightening the egr pipe nut to the cooler with such little room for movement.
Any tips for doing this?
Should i make a tool for tightening the nut by cutting or bending an open end wrench or have you gotten by with something you already had? I've used a vise grip and that was a pain in the ass.
Also, the studs ( #21 in the pic ) originally used to connect the egr pipe to the exhaust manifold have been replaced with bolts. Should studs be used in this situation at all times?
