EGR or O2 Sensor issue (s)?
Ixonia, WI
My CEL came on about one week ago. I took it to Autozone to get it checked out. It turns out there was a problem w/ the O2 sensor. Code PO135 came up (Bank 1 Sensor 1).
So I purchase a new Bosch Premium O2 Sensor - part # 15728. I intstalled it and double checked the wiring to ensure it was correct. I replaced the sensor that is right before the catalytic converter (passenger side).
I then disconnected the negative on the battery and reconnected it after about 1 minute. Started my truck and took about a 5mile test drive. CEL light stayed off....about 25 mi later, CEL appeared again.
Back to Autozone....this time same code PO135 came up & a new code - PO402 which was told was the EGR. Was quoted $200 for a new EGR.
Just does not sound right.....Any help or ideas on what I do next is appreciated. I am not afraid to get my hands dirty.
Thank you,
:beer:
Jerry Rivera
97 40th TLC, stock, 140k, no lockers
want: 4" lift, fr & rr ABR bumper, 33's
egr
do a search, so many posts on this one... I did mine last year...a lil' ticky, but not horrible (I did all the egr components though)... I can't remember if the 402 code was excessive flow or unsufficient flow, regardless, not gonna hurt anything if ya have to drive this way for a bit... just annoying... more will chime in...but do a search & see the pics that others have posted...
Check to see if there is carbon in the modulator per the link I posted.
What you need to do is check and test each part of the EGR and only replace the bad parts except the modulator, if you have the old style you should replace it.
CDan can get you a modulator for way less than $$$.
