EGR modulator
Saratoga Springs, UT
I replaced the modulator and cleaned the hoses but I didn't mark the hoses well enough. My 80 is a '94. There are two hoses near the valve cover, one cloer and one further away. There are two connections on the modulator that these connect to that are beside each other on the modulator, one that is nearer the firewall, one nearer the radiator (the 3rd goes to the valve and I know which one that is). So which do I connect to which. I tried swapping them with the engine running to see if it would be obvious but it wasn't. Thanks for any help.
The one closer to the firewall should go to the lower hard-line. The one closer to the radiator should go to the upper hard-line.
Hope that helps. I just looked at my FSM, too cold to go outside to look at mine. I just did some work on that area this summer, so that should be right.
Sweet 45 by the way!:clap:
the ports are marked on the throttle boady and on the modulator "Q" "R" "E" etc, take a look at the sticker under the hood it will show what goes where.
That's too funny. It was right there in front of me. Of course, 50% chance of getting it right and I had it wrong. Thanks for the compliment on the 45 and thanks for the help!
