EGR location
Fort worth, Tx
Curious as to where the EGR pipe is located on the FJ80 (91'). I have a failing fusible link issue (the link with the gray connector) keeps "opening up", so I have a short somewhere. I have read in past posts that a common short area is in the wiring harness that runs across the EGR pipe? Pictures would be beneficial! I have a no start condition, but when I replace the fusible link, I am able to get it going for short distances until it dies again...thanks.
S
That issue you speak of is on the 93+ trucks. The EGR on the 3FE is a large accordion-ribbed thing on the driver's side of the motor and doesn't get close to any wires. Many people remove theirs so if you can't find it you just may not have one.
Not sure about your fusible link situation, but there are many gurus here.
