MissahPapaJ
Snack Lah Bler!!!!
How’s your EGR piping routed. Pics would be great. I’m now wondering WTF I’m guessing the engine assembly was swapped at some point and the powers that be decided it was the fix.Can't tell you what goes where (mine's a 94), but I agree, the PO or whoever did that should not have had access to tools!
That blocked off port in your photo is what looks to be tapped but doesn’t have a center hole in my last photo so I’m guessing this head is for a market that wouldn’t have a EGR but someone made it “work” did all 80 series in the US have EGR systems? I assume so. I don’t throw any EGR related codes so I guess I’m stumped for now but hopefully someone comes through with some knowledge.Mine’s long gone, but used to come off of EGR and then down to a port on the head on the driver’s side…
See my last pic it looks factory non-equipped so I’m wondering if it’s a head or engine from a non-US market non EGR equipped area, I know AUS 1FZ’s didn’t get EGRs so now I’m wondering about Canada and Japan. The engine bay doesn’t scream swapped to me but I’m probably wrong.It bolts to the back of the head I believe.
Here's a pic with a block off plate as EGR delete's seem somewhat common.
The battery has been disconnected multiple times, everything is working with the system as ugly as it looks but I’m about to delete the system.That's just....wow. I'm impressed you don't get a code. "If" the EGR actually works, pulling from the exhaust pipe like that, how does the temp sensor register properly? It would suck if you disconnected the battery and reset the monitors then had it not set again.
As Ghetto as it is, someone put some thought into it. Probably during reassemble after the head replacement. It would be more like "OH". we cant bolt this on.
This also make me wonder what this head fits. If its even for an FZJ.
Temp sensor is behind the flow of EGR passage through the intake so all it has to do is see a heat change during EGR activation.That's just....wow. I'm impressed you don't get a code. "If" the EGR actually works, pulling from the exhaust pipe like that, how does the temp sensor register properly? It would suck if you disconnected the battery and reset the monitors then had it not set again.
This also make me wonder what this head fits. If it’s even for an FZJ.
Correct. What amazed me is the temp difference pulling it from the head vs just past the cat and the system being ok with it (so far). My 96 has had a history of temp codes starting from about a year old. 280k and a couple of decaids later, everything new including engine and the problem still exists. Pops the code about once a year (same as all the dealer paperwork I got with it). Make me wonder if the egr system is happier sampling the exhaust from there.Temp sensor is behind the flow of EGR passage through the intake so all it has to do is see a heat change during EGR activation.
EDIT. Answered my own question with a bit of reserch. heres a clip from some of my findings.
EGR is the main source of carbon deposits in the intake paths and on the valves — pulling from after the cat means the gas has already been through the three-way catalyst, so it's cleaner (less unburned HC/soot) before it gets recirculated into the intake tract and onto the intake valves.
huddexpo.com
I’ve got a 96 just ordered a kit from Hudd. FTW.Bypassing EGR codes
1993-1994 FJ80 EGR Temp Sensor Test Plug Kit - HuddExpo 1993-1994 FJ80 EGR Temp Sensor Test Plug Kit - https://share.google/0lanlfUdI5lTTgPd5
I installed on my 93 prior to HG....to bypass the annoying codes. Cleaned the carbon build up when doing the HG thst fixed the EGR code.
