EGR cleanout???
NJ SUCKS
Website
www.recordme.com
Any of you ever clean the carbon from you EGR Valve and make the evil CEL go out?
Know the $$ from cDan for new one?
How many miles on your 80's before the EGR went bad?
TY
Dan
Dan,
Do you have a P401 code?
I have been going through the P401 hell for a year now;but I think I finally solved it, but not sure only have gotten about 250 miles on it since the last work and MIL reset.
There is a thread on page 2 or 3; P401 or Seppuku; go through that and search for other threads for ideas and suggestions.
The basics; check all vacuum hoses; if they are cracked, old, stiff, and are too easy to pull off, then replace them. Just pulling them off I think can make them leak, if they are dry and old, IMHO.
Clean the sh-t out of your intake and throttle body; no time for pussy footing around. Remember to clean the little ports on top of the throttle body; there are three of them; use Carb cleaner, pressurized air, and a little wire if you got one to probe the tiniest ports for blockages.
If you have an FSM (Factory Service Manual) follow that. If you don't; get one.
If your vacuum modulator is full of carbon (pop the cap off) then your EGR probably has an internal leak (means it is broke) and the Vac Mod is caput also, but there are testing procedures.
Everyone on the forum appears to feel the major culprit is the VSV; there are checks for that; follow the FSM for that also.
Carefully disconnect the electrical connectors to the VSV, the temp sensor, and the VSV harness and clean them with CRC electrical connector cleaner, put them back together.
You can buy an autoranging multimeter at O'Reillys for $30, follow the FSM
on how to check the VSV.
Lots more, but read the other posts to get your bearings.
g
Thanks Gray
I have been over a year with this light taunting me as well I'll look into all the info you sent asap.
Did you ever try to clean out the ERG proper and if so did it help? Hope the nasty yellow light at your end is out for good (fingers crossed)
I ll let you know if I ever reach that elusive nirvana over here
Cheers
Dan
Thanks Gray
Cheers
Dan
I did clean my EGR valve the lazy man's way; you disconnect the EGR temp sensor connector and then unscrew the temp sensor; if you're not sure; it is just on the other side of the intake from the EGR.
Then you can take some thin tool and probe in toward the EGR from the temp sensor port and you will be into the EGR port. You will see what I mean as soon as you look at it. ie: they are almost directly across from each other and share
the same internal "tunnel" that goes to the front of the throttle body.
You can scrape around and see if you get any crud; you may not get any big chunks out; surprizingly, mine was wide open. (However, I had sprayed intake cleaner into the temp sensor port previously which probably cleaned it out).
But now that you are there, you can spray carb cleaner into the temp sensor port; it will try to run back, so you can spray, then plug it quickly to let it percolate.
Then, you can spray a full can, at least (2 better, at least) into the temp sensor port with the engine running.
The engine will not run with the port fully open, so what I do is put the temp sensor back in, but only like half a turn; then start the engine, then get my can ready, then unscrew the temp sensor and quickly put the red extension from the carb cleaner can into the port and cover the open area with one finger.
Now the trick here is, if you are alone, to keep the engine running while you are spraying the cleaner. You can reach the throttle with your hands; just have to do it to figure it out. Much easier with help.
I also would spray a minimum of one can into the PCV port going into
the throttle body, and one into the brake booster port (not the brake booster) ie: pull the brake booster hose off the intake and repeat above, using a full can.
This does not have anything do with the EGR; but while you are at it,
the idea is to clean the intake from the various ports as they each will flow into the intake in a different pattern, cleaning different areas, at least that is my theory.
The areas that theoretically will have the most crud and which would benefit most from cleaning would be the EGR pathway (cleaned via the temp sensor port), and the PCV port.
That was a bit long winded; just use at least a few cans of throttle body/intake cleaner, check all your vac hose, and all the electrical connections.
G
My system had the EGR port totally plugged. Kept throwing the code and no one could find it. That is the port that runs along the top of the intake plenum and opens into the top of the throttle body. IIRC. I had the whole thing apart to get to the injectors at the same time. Once I found that plugged port, I felt sure that was the problem. I would hate for that plug of carbon to be ingested in my engine. I guess a lot of intake cleaner might break it up enough to small pieces to do no harm. While the intake was apart to service the injectors, I installed a new EGR valve, new VSV and all new vacuum lines. I cleaned all the little vacuum ports and the top half of the intake too. That was over 50k miles ago and no CEL light.
Oh, and the truck ran like new after all that !!!
I just tend to think of the EGR system items as having a limited useful life and I didn't want to go in there again chasing the CEL. 10 yrs and 145k mi. seemed like they had done their job. The VSV is the bugger if you don't take the intake apart, but it can be done from below I am told, and after studying it, I believe that. Might have to have smaller hands than mine, though.
Agree with Super90;
The EGR system on the 80, I now believe, is destined to fail sooner or later. My 80 did not start giving me trouble until around 180-200K, so I got off better than most.
If someone has the ability and the time, it would be best to take the throttle body off and the top half of the intake off; that way you can clean them directly and manually(soak and scrub), clean out all the little passageways and ports, and at the same time replace your VSV and all the little vacuum hoses underneath the intake that get dry and stiff from age/heat.
I don't like replacing parts without a good reason, except maybe in this situation; from all the threads I have read and from my own experience over the last 1 1/2 years, we know all the parts wear out and/or get clogged up, sooner or later. The exception to this is that we have learned the temp sensors seem to survive, at least long after the other parts have failed.
An additional benefit of pulling the intake off is that once you have all that out of the way, you can more easily replace your PHH (Pesky Heater Hose).
In hindsight, wish I had done it that way (had the time and place to do it I should say).
Good luck, let us know how it turns out.
g
Yep, I did all my heater hoses at that time. They were very easy to get to. PHH only took an hour. The big hold up on the job is (1) having a big enough wrench to get the EGR valve off (2) having the female torx sockets to remove the mounting studs for the EGR valve (3) having a flex combo Gearwrench for the upper bolt on the metal tube for the PHH. With all those tools in hand, the job is not so bad; you just need a weekend to work on it. It took me a few more days since I had the injectors out for servicing for a couple of days.
HTH,
Thanks for all the help!
You guys never cease to amaze .I am humbled by the know how and gumption .
TY so much.
I ll let all know how I make out
Dan
