EGR and VSV Operation
I started troubleshooting my EGR system this weekend. The EGR and modulator checked fine or seemed to, more on that later.
When I was checking the function of the VSV during a drive test, I saw vacuum between 5-10 in Hg when the engine RPM was above 2,000. Vacuum went away at idle as expected. The same behavior repeated but then went away, during the rest of the test drive I saw no vacuum under any engine condictions.
I was wondering if anyone else has seen this behavior, whether it is indicative of the solenoid shorting when the engine heats up. I haven't tried a second test drive to see if the problem repeats.
I also haven't run FSM checks on the VSV which seems to check for a solenoid coil short to chassis.
On the EGR test, I didn't get the engine to stumble with vacuum applied to EGR on the modulator side. The EGR did function correctly and stalled the engine with the EGR DS hose pinched and vacuum applied to the EGR.
Sidenote: pulled the EGR modulator hoses from my 2000 4Runner to run the LX450 drive test. There is a nice tee of hoses that I plugged into the LX to monitor vacuum on the PS hose of the EGR.
