Efi relay
Amelia (east of cincy) ohio
Just picked up a 92. Last week in the woods it died a few times and would only restart after sitting about 10 min. The efi relay was very very hot so.im thinking it was a relay issue. I have done some research and I seem to find people saying the wire needs to be upgraded and some say some component in the fuel system is drawing too much and needs to be replaced. Which is it typically?
I also have a 91 and I havent had efi relay issues. But it came with spares in the glovebox
Typically it's the wire.
However I've installed adhesive heat shielding to my underhood fuse box (looks like a foil quilted blanket), and haven't had an issue in a few years. I'm desmogged, and have a custom exhaust, so my fuse box gets nailed with heat.
Posted this on a similar thread.
I replaced my fusible links first when this happened to me, but that did not correct the problem. I eventually (through the expertise of jonheld) narrowed it down to my EFI Relay. The only thing that is not similar is that my LC never died while driving. I would pull into a 711 in Japan, get some grub, and then it wouldn't start back up. Used to take my EFI Relay (OEM Metal relay) out using gloves because it was so hot and go put it in the 711 freezer to cool it down. Always started up right after that. In the end, swapping to the camry (corolla?) plastic EFI relay that jonheld recommends completely eliminated the problem for me. I'd recommend at least trying that.
Here's the part number
