I've been chasing a weird idle problem for years now, I go through phases where it drives me insane enough to chase ghosts but in the end I always figure the truck is fine and I'm just being anal. (anal, get it, haha. (nelson))
Anyway, I went around checking the resistance of the tps, iac, and a few other things.
MAF - Good
TPS - Good
IAC - Good
My EFI Relay came out this way...
Pin 1 & 3 no continuity
Pin 2 & 4 76.4 ohms...
Something is wrong here. Will it cause a rough idle, it'd seem to me like if it was bad then the truck simply wouldn't run.
I note a very fine amount of water (NOT COOLANT) coming out of the tube that goes in to the bottom of the EGR modulator when the modulator is taken off and the truck is idling. I assume this is normal...................
My idea of rough idle is some shaking while cold and light shaking sitting at a stop light in drive. It smooths out in neutral when warm.
edit: After reading these threads about the fubar harnesses for months now and checking the outside of mine....... I'm cutting mine open and actually checking them closely.
MAF - Good
TPS - Good
IAC - Good
