EDIC Motor Relay
Calgary, Alberta
Hi All,
So, I was wondering if anyone has any good pictures of the EDIC motor relay for a 1985 BJ70 with a 3B engine? I've got a new motor but the arm is not changing position so I wanted to check if the relay was shot. I looked around on the forums but cannot find a good description for or picture of the relay and its location for the '85 BJ70 with a 3B engine. Could be stupid and blind though :)
Thanks in advance!
It's almost always the fuel control relay. Water often gets into the relay box and causes the circuit to fail. Sometimes they can be repaired by cleaning the circuit board or re-soldering any poor connections.
The relay is usually located in a kick panel.
~John
Thanks! Found it and the thing was just unplugged, lol. Plugged it back in and she's running great -- though now I've got loads of black smoke when I accelerate --> not sure why...
Might be stuck in the over-injection position. If you pull off the control rod between the EDIC motor and the pump and that reduces your smoke, then it's in the over-inject position.
If you have an engine manual, have a look at it to see what i mean.
~John
just try screwing the fuel stopper in a turn or two until you start loosing power , or the spring in the stopper may be sized or broken. This is located on the back of the pump under the arm the edit hooks to. It has a funny lock nut and may still have a lock wire in. Clockwise ,in,less fuel .
