Edgestar 43 quart fridge question ???????????
Jordan
Can you please let me know what my problem is with this fridge? The Fridge runs fine on AC 220 volts. It also runs fine on 12 volts with the engine OFF for 28 hours and still has juice to start. The problem that I have with it is when the engine is running it keeps blinking yellow led labeled “low voltage “. I have hooked up the Voltmeter to the fridge wires while it’s running and engine is OFF and it measures 12.5 volts while it’s recycling. Turn the engine on and the voltage will start climbing until it reaches 13.8 the yellow light will start blinking. The voltage will continue to climb to 13.98 while the fridge is cycling. At 13.8 and up, the yellow light starts blinking and the compressor stops and voltage will climb up to 14.5 while compressor is not recycling but will never surpasses 14.55.
My LC has two new batteries wired together for a total of 190a/h but I have individual manual switches on the Negative “ground” of each of them. So when I am camping I just switch one of them OFF.
