Post #2 was pretty close. The ONLY thing the ECT switch does is alternate between two "shift maps" in the Electronically Controlled Transmission (ergo: ECT).
The "NORMAL" position is mapped toward early upshift points and deeper downshift points. I prefer this mode for towing a trailer because it allows more pedal travel to modulate speed without shifting.
The "POWER" mode is mapped for later downshifts which allow you to stay in a given gear a little longer presumably for better acceleration. The downshifts happen a little sooner, basically at a lower throttle pedal angle, so you get an earlier downshift, again presumably for better acceleration. Sometimes this causes busy shifting, or gear hunting when driving up hills or under load because the difference between a downshift and the following upshift are closer together.
A shift map is two dimensional map composed of Vehicle speed on the horizontal axis, Throttle pedal angle on the vertical axis. (V vs TA)
And, if you made it this far through this post, you can probably make it through some of the Owners Manual as Curtis recommends, but I don't think the O/M explains it well enough.
Some people are convinced that it gives them more power, most people don't feel any difference. One way to feel a difference is to accelerate in NORMAL mode in Overdrive (4th gear) to where it feels like it will ALMOST downshift, hold the pedal steady and then switch to POWER mode to find the difference. It might take a little looking, but when you're close to the downshift point and then make the switch to POWER, you'll get a downshift without pushing the accelerator more. WooHoo!
Sorry for the long post, it's what I do!
Dan.
