ECM problem for 2F engine
:doh:Hey yall'....I'm new here and have a question...hope you have an answer for me...I've just changed my '78 FJ40 to a TBI and a new DUI HEI distributor...I'm running it with a ECM from a S10 but it's not right.....stalls after a few minutes..then restarts but won't run for more than a few seconds. Do any of you have any experence with these ECM's?....any better solution?....like a programable system specially made for this engine......
Stuck in the mountains of West Virginia.......windsail......
I believe Howell can burn you a chip that works well with an EFI'd 2F. There are also a few folks on the board who have burned their own chips. I do not believe there is a stock GM chip that will work with the 2F. The 2 EFI systems I have came from Up & Over Innovations in PA but I'm pretty sure they no longer sell or support EFI stuff for 2f's.
Nick
Thanks man.....here's a not so good pic of my cruiser......Grizzly Grip finish .....windsail......
you will need to find someone with a eprom programmer, and get a correct for the 2F .bin file programmed on it. Its really simple if you have the correct tools. You will need the correct eprom(or use the one from your ecm) and a UV eraser and a eprom programmer.
Tuning on the other hand is much more time consuming, although a romulator makes it a bit quicker.
Skip the freeware software for tuning. Just go right to tunercat, or others. I havent had luck with the free ones. Seems like small little details are overlooked, for example, changing the VSS from magnetic to optical wasnt possible to do correctly on the freeware I used.
PS stalling after a few minutes sounds like another issue. Usually just plain rough running, lack of power are the giveaways for out of cal eprom. Try taking you gas cap off and seeing how things go. I have run into folks that omit the charcoal canister purge valve and have similar issues.
Brett......you may be a genius.....where do I send the check.....I just went out and took the cap off...started up and left it run for 20 or so minutes...wouldn't have done that before.....
Last week I installed the DUI and at the same time I took the tank out for cleaning and blow-out....Do you think I could have mixed the lines up somehow?......I thought I was reattaching them just as they came off but....:doh:.......it coulda' been my mistake.
I will give it a road check tomorrow....too late and too cold tonight....don't wanna' get stalled out ten miles from home tonight.......
This cruiser runs great when it's running......other than running too rich it seems to me......
Thanks again man.......windsail........
