I just finished my HG PM and the rig started right up just fine.
I do have a P0330 because I broke the connector off the #2 knock sensor(oops!). My question is since this is one of the Diagnostic Trouble Codes (DTC) that will put the ECM into fail-safe mode (in particular this code dictates max timing retard) Will there be a possibility to store any other codes? I'm not seeing any others considering the problem I'm having.
The cruiser will not go into open loop at all and my scan tool verifies this. I can see the coolant temp increase and there is no P0125 (Isufficient Coolant Temp for Closed Loop Fuel Control). B1S1 O2 sensor is not producing any values but the rear O2 sensor is reading fine. I did an Ohm check and the sensor is fine.
Any ideas, opinions?
