So I bought the L-5 Eccotemp and played with it once in the woods without the fittings all tight so it obviously leaked but even then, still worked great. Did the trick at the time.
Fastforward to about 20 different water fittings/quick connects/adapters later and I have it all pipe-taped up, quick connects in place, Shurflo pump hooked up, battery powered up, ready to test it out for real.
Go to hook up the simple flared nut gas fitting for the propane tank, and then, in one huge brain cramp, I snap the damn fitting right off inside. I got too excited seeing the light at the end of my tunnel and have this thing pumping out hot water in my garage without leaking. OOOh the anticipation! It's a flare nut fitting that I know better than to crank on, yet somehow my brain shut off.
Then I bust the casting/fitting right off.
Now I'm screwed. Guess it helps to be smarter than the equipment you're working on. Stupid Eddy..........
Try warranty first, then replacement parts. Simple fix if they will even sell the parts. Probably some nasty liability with gas so maybe not?
Now I'm screwed. Guess it helps to be smarter than the equipment you're working on. Stupid Eddy..........Try warranty first, then replacement parts. Simple fix if they will even sell the parts. Probably some nasty liability with gas so maybe not?
