ebrake blues
Hagerstown MD
I'm not sure if I got the arms inside setup properly, those damn clips one use only??? the main axle also has a cresent-shaped clip as well, this thing is a real PITA to crimp. I also tore my adjuster boot. Any place sell all of this little stuff seperately? are these still available from toyota?
Next up rear Xsfer case seal. I pulled the rear yoke out and oil poured out. Is this seal bad? Any suggestions for a source? I pput new shoes on this thing as well as new hardware I found in the glove box (thx PO). still I have jerk those clips around a few times, On off, On off, Dooh!!! back off, on again.
The little clips are still available from Toyota. SOR sells them as well. SOR also sells an e-brake rebuild kit that I used and thought it was a good deal.
On the t-case, the seal may be bad, it's pretty easy to replace. It is also possible you just need to seal the splines of the output shaft-Permatex works fine for that. If you tear it down far enough to put permatex on the splines, just replace the seal while you are there. It is not a difficult repair.
I have read about a piggy-backed seal or two seals put in together on the rear seal for the transfer case. Can someone explain this to me in some detail. Is this a hard thing to do, what is involved here for this modification.
Is it normal for oil to leak out of the tranfer case with the rear shaft pulled out?
