This may be on here already, but I thought I'd show how I put a standard gm alternator on my 40 in a snap. All you have to do is remove the original F engine alternator bracket, cut off about 1 5/16" off the face of the bottom hole and then you can put a regular $35.00 gm alternator on the F engine with no special brackets, kits, etc. I used a porta band saw to make the cut, if you have access to a regular band saw, it would be a breeze. Here's a link to some pics of what it looks like when installed and the piece you cut off. I'm running the alternator as a 1 wire, one wire running from battery to bat terminal on alt, and a wire jumped from the bat terminal to #2 terminal. I don't have to run switched power to term 1, just rev it up a bit and it works fine. I'm not sure how long this setup will work before I have to put in a switched power wire, we'll see. Good luck, Richard
http://s195.photobucket.com/albums/z43/rlg999_photos/FJ60/?action=view¤t=100_2325.jpg
http://s195.photobucket.com/albums/z43/rlg999_photos/FJ60/?action=view¤t=100_2331.jpg
http://s195.photobucket.com/albums/z43/rlg999_photos/FJ60/?action=view¤t=100_2329.jpg
