Easiest way to get DRL's?
Hi guys,
I just bought a 1996 FZJ80 and I love it. Unfortunately the provincial inspection requires it to have daytime running lights. This is probably not applicable to most folks, but has anyone been able to rig something up to suit this purpose? Until I do, I can't get it registered/drive it :mad:
Thanks
Regarding the fix (and answer to your question) I'm interested in hearing the answers from those here that are much more knowledgeable than me. I have nothing of substance to offer so ignore the remainder if you are looking for substance :)
Regarding the requirement for DTRL on older vehicles , I'm surprised there isn't a 'grandfather' provision for those vehicles produced prior to the requirement. And if there is no provision, I would think that many shops in your area would be knowledgeable about retro-fitting something (surely you're not the first to have a pre-DTRL vehicle not pass inspection - so it must be a common problem).
For that matter, why can't you just leave the light on all the time? They have an auto-off feature so the battery won't die, and they will always be on when you start the car. I know all my newer vehicles with DTRL have a switch that allows me to over-ride the lamps, so the fact that you could turn off the lamps can't be a problem. I say just leave the switch turned to on (tape it in that position for the inspection if you need to ;) ).
Good luck!
All cars require DRL's in your province? Even though it did not come with that option in the factory? Hummmmm...... You may have to wire a lower voltage to your headlights.
Canadaian Tire has the module you need.. it's about $25 if I remember right!!
You can install it yourself, but they'll install it for around $100, everything in.
If it were me I would just figure out what wire in the stearing column needs to be hot or ground for the low beams to turn on. Then give it what is wants...like jumper it to hot or jumper it to ground. But that is only if you are comfortable working with electrics.
They have to be activated through the parking brake, some shops and I think riv is very particular on this.
Just buy a fog light kit that comes with a relay or purchase a relay.
Mount the lights and wire the relay to the ign.
It shouldn't be that difficult, you can pick up the stuff you need for around 50.00 usd.
Bonus that you get some fogs or drivers out of it.
ken
They are grandfathered in cars originally sold in Canada. As this Cruiser is being imported from another country and was built after DRLs became law in Canada, it has to have DRLs to pass the federal import inspection.
Here's the photo of my jury-rigged system (it passed the federal inspection at a BC Canadian Tire shop):
The headlights are on all the time, at the same brightness as the regular "low-beam on" setting. The only thing the light switch does is turn on the instrument lights and rear markers. And of course it operates the high-beams.
Regarding the requirement for DTRL on older vehicles , I'm surprised there isn't a 'grandfather' provision for those vehicles produced prior to the requirement...
...For that matter, why can't you just leave the light on all the time? They have an auto-off feature so the battery won't die, and they will always be on when you start the car. I know all my newer vehicles with DTRL have a switch that allows me to over-ride the lamps, so the fact that you could turn off the lamps can't be a problem. I say just leave the switch turned to on (tape it in that position for the inspection if you need to ;) )...
The grandfather clause is for Canadian vehicles only as someone mentioned. Even then, it is for vehicles built pre-December 1, 1989, so no go.
I had the same thought about taping the switch on, but the guy was pretty strict about it. I doubt it would fly. I just picked up the kit from Canadian Tire. Looks decent and says it meets or exceeds all government regs. I guess I'll find out!
Thanks for the help all.
