Early year Steering column
Salem Oregon
Still trying to figure out what to do with my 66 steering column . Installing mini truck PS . Keeping the original or go tilt wheel the original looks kind of cool but leaning toward some kind of tilt wheel.
Main question is what kind to get... No key or shifter in column and how to attach to firewall . Saw the JTC column looks great but lots of bucks. What GM column should I look for instead. Have not seen any info for the early model install . Any help appreciated
Thanks
I just completed the mini PS conversion in my '69 FJ40. It was very straightforward - I kept the stock steering column for ease of conversion and because my '40's not a DD, so no need to get fancy.
I initially cut the steering column right at the box which allowed me to keep the spacer that was inside the shaft. I then measured the actual length that I wanted the column to be, and re-cut. Then I was able to use to spacer to recenter the actual steering shaft inside the steering column before attaching to the new gearbox. Piece of cake, extremely inexpensive (the whole project cost me $20 since I got the box and pump for free) and one of the best mods made to my LC.
What I will be doing is swapping the fire wall section for a late model one so I can use the factory ps setup. Here are some pics from a 45lpb. Not my rig.
