Early wiper wiring
Boonsboro, Maryland
I have read and printed out how to wire the seperate motors and switch on my crusier. but how in the hell do you go about fishing the wires through the frame or what is the original way they ran the wires.
Were any part of the run outside the windshield frame?
There are 2 small holes to use, one is for mounting the other I assume for wires. Very small. I drilled it out a bit and have bailing wire in the hole for the motor arm, but cant fish it through the little hole. But I dont know if the wires will go. I was thinking of getting some 20ga. not sure if it is thick enough. but it sure would fish through better. Any tricks, or insight. Thanks.
On my 64, the wires were run in a bundle along the inside edge of the windshield frame right next to the windshiled gasket. If you look closely, you should be able to find a few small holes that are for the screws for the wire clips.
Without looking, I can't remember how the wires get from beneath the dash to the glass, but I'm pretty sure they run through the lower portion of the frame (where mine has the big vent).
HTH,
Eric
the wires only go into the frame at the very bottom. the run along the underside on the top, then down the inside on the left and push straight through on the bottom.
I figured as much, We will see if I can get them fished through.
I know where all of the holes are.
We will see how it turns out. I think I will run them along the outside up top and then go through the frame on the side piece. make it look a little better.
Thanks guys.
