early steering box rebuild
I am rebuilding a steering box to go in my early '68 FJ40. In late 1968 the steering shaft and steering wheel changed. The number of splines on the shaft and steering wheel went from 36 to 33. Here is my quandry.
I have two later steering boxes from the 69 to 72 cruisers (33 spline) and an NOS steering shaft from the early cruisers (36) spline. All of my steering wheels are the earlier 36 spline type. If I tear down one of the later boxes, will the early 36 spline shaft fit in the later 33 spline box? If I look at SOR, all the parts (bearings, bushings, seals, shims) appear to be the same part number. So, I have to assume the answer is YES.
I don't want to pull the working (but leaking) box off my cruiser because it will take me weeks to get the box rebuilt and I have to have my cruiser to drive. Thanks.
OK. I am getting another steering box from Osagecruiser. Now, how about a pitman arm puller -- what do yo recomend? I see that lots of you have broken them. This morning, I cut a pitman arm off of one of my old boxes with a dremel. Not much fun.
Pitman Arm Puller
When I rebuilt the suspension on my Camaro, I borrowed a puller from my father in law. He had one that he used once 20 years ago. Before he came over I was planning on heading to Pep Boys. They had then for rent. Pretty cheap IIRC.
i used a harbor frieght one....broke the first one....so i took a different approach on the second one...i started by applying gobs of pb blaster...than started cranking and beating on it...cranked it down...more pb blaster and let it sit overnight...next morning more pb blaster more pressure...i think after a couple more attempts it finally popped loose...patience...it will come off...good luck
osagecruiser
