Early Bib stud
McCall, ID
I am missing the nuts from my new/old early bib on my fj45. This is the bib with the parking lights built in, different from later bibs. On this bib there are 4 studs which attach the grill to the bib (later bibs use nuts and bolts). The studs are welded on and appear to be original, but I don't know for sure. They are an odd size, and after spending an hour at the hardware and auto stores, I am pretty sure they are JIS 5 mm 90 pitch studs, and, of course, no one has the nut to fit them, that I can find.
So anyway, before I go too much further in this, I'd like to know what others have or know. Maybe they are a PO mod, in which case I'll just cut them off and drill new holes.
Here's what I'm talking about.
That would be great!
Dave you are correct, they are a bastard size, I think two of mine have no nutz on them as a result:D . I have no idea why they do that.
Ed
Well, I just tried the 5mm .90 pitch die on it and it wasn't right. So maybe its a 80 pitch. Or something else. Weird.
I guess there's no question that the Studs are the way they came, then.
IDave, this has nothing to do with your question, but I had to ask, what color is that bib painted? Do you have a full picture of the rig painted in that color? If you do, please post.
Thanks
Scott
Thanks
Scott
Oh, OK.
:D
It's this stuff, with 14079 Green written on the lid.
I....WANT.....THE....TIRES......IN......THE......BACK......OF......THE.....45!!!!!!
Hoarder!
C'mon!
Ed;)
Hoarder!
C'mon!
Ed;)
Sorry, Ed. That was last year. They's on the rims and on the truck now, siped and sweet! (except it isn't running just now. :o )
I assume they are 33x9.50 BFG MT's? Where did you get those even a year ago????
I am so jealous.
Got these OEM steelies and it looks like I have to settle for AT's.
Bum Ber!
Ed:frown:
Haystax helped me out there. The 9.5x33s were too small for him!
Poser said:
Miss his sig line??
Yes Dave, they are a very non-common size nut here for most hardwear stores....I may have some however...
-Steve
Sweet!
For future reference...
These are a 5mm stud with a .8mm pitch thread.
So you will need a nut that is 5mmx.8mm pitch thread to work with those studs.
You have PM Dave.
-Steve
Thanks, Man!
Toyo FJ40 said:
Any chance that some of those stamped spring Nuts (Palnuts) would work? they should flex enough to fit your stud if it's close.
Kevin
That looks like it might work. I suppose they would have to be 5 mm, or maybe there's enough leeway?
