what years had the smooth drive cables for the antenna masts? i can only find info on the later tooth style cable and i got a setup that takes the smooth style cable and has to be taken apart to replace.
My 94 has the smooth cable. I am guessing 91-94 or 93-94.
Mine still doesn't work, even with a new mast & cable. Works for a time, then it just starts clicking and wont go up or down. Thinking about just going to a fixed mast.
I believe the toothed style is late '96 and '97 for the Toyota and all Lexii 80-Series.
The toothed style is used when the antenna is the 'return to last position' type. Personally, this style antenna sucks and is far too fragile. I have had 2 fail, the original and 1 new replacement. Someday I will replace it again but it seems to get good reception with about 1" of the mast sticking out of the fender so I'm leaving like this for now.
FWIW the toothed style (usually) has to be taken apart to replace because the cable breaks inside the retracting mechanism. This is probably the most common failure on the later trucks (96-97). Every time someone posts that they have a new-to-them '97, the pics either show a broken mast or they mention that the mast is broken or one of their first posts is a question on how to fix the antenna. I would speculate there has been a 100% failure rate on this particular part.
