E-brake specs for '74
SoCal
What should the outer center section of the e-brake mic to? Picked one up that looks to be in very good shape and want to be sure it hasn't been turned down. Thanks for any help.
Going off the speedi-sleeve number, 99177, it is for use on a shaft with a diameter of 1.772...
Info here...
From the techtrivia section....
Rear output, where the emer brake drum resides:
Seal - NOK AD2651E
73- 3sp Speedi-Sleeve - CR (Chicago Rawhide) 99177
74+ 4sp 4Speedi-Sleeve - CR 99189
The information in yellow above is not correct. There was only one seal used for the rear output shaft/parking brake drum configuration on the one-piece Land Cruiser transfer case....
