Got the 40 prepped to spray. For those that have done this before, did you brush the coating up behind the front door jamb pillers? It looks as if the area is to tight to get the gun in. How many coats did you put on? What air pressure did you use? How well did the masking come off? Did you strip the masking right after spraying or did you wait til it cured 24 hrs.? Is there an advantage to coating the rear sill as Osagecruiser did?
Thanks Brad
Thanks. I had read most of those posts before. There wasn't any specific info on air pressure for the spraying durabak. I will just play with it till I get the results I am looking for. I didn't see many pics, most of the links are dead. I was interested in seeing how many people coated the rear sill area just above the rear exterior frame member. I am using grey and was wondering how different it would look against the white body. A grey strip sandwiched between the white tailgates and black frame member. I was also really hoping to hear about getting into the nook behind the front jamb. I will try a brush and see how it works. Thanks again, I will post back after the job is complete .
Brad
Use a undercoating shutz gun
35 psi
you can strain it some for less grit
2-3 coats suggested IIRC
one gallon will do.. 1.5 would be better
do it in your front yard like a true redneck
Thanks for the psi info. I was hoping to put it on today, but it looks like thunderstorms might be coming in again. Didn't get any rain yesterday, but the wind was bad. How fast does this stuff set up in high temps? It was 108 yesterday.
Brad
Your durabak job looks great. I am doing the same color. Did you thin it at all? Did you strain yours? Did you use a medium strainer?
Thanks again
Brad
I did not thin...did not strain. They told me to strain for a smoother look. ( after I did the job)
IIRC you cna order it without grit( texture) if you want.
If I did it over I'd a thin very little but put more coats on .
3-4 thin coats would be better than one or two heavy. Put more on the wear areas if you can.
it dried fast as I recall ... after I got done i would start again wher I began.
Read the instruction and call the mfg.
IIRC this stuff is made by herculiner company according to dieselcruiserhead on this board.
I used a qt size gatoraid bottle duct-tape to the gun . My hopper was too small and I didn't want to refill evert two minutes. The gatoraid bottle kind of fit but the tape was to make sure it did not fall off. I just could not find a plastic container that woudl fit the threads better.
