dumb sas question
west elks, co
keep blowing up cv axles...time to swap, currently getting pieces and parts together.
so...anyone know the hole to hole measure of common leaf's for the front axle? working with a 91 mini, have a set of leaves out of the back of maybe a 90..?..sitting around, sure would be nice if they were an good length.
and yea, i do realize that i can make whatever i want work, as there'll be nothing there when i start assembly, but if i could avoid mounting hangers twice (assuming i replace the partially worked leaves at some point), it'd be nice. hope that made sense.
thanks for any input
doug
http://www.pirate4x4.com/forum/toyota-truck-4runner/265669-rear-up-front-faq.html
Above is a thread with all you need to know about swapping toyota rear springs up front for sas or as a front spring.
89 to 94 pickups have longer rear springs 51" I think.
84-88 pickups have shorter more commonly run rear springs for rears up front at 47"
These mearsurements are taken along the top leaf. I have the shorter 47" springs up front my 89 pickup.
thanks...measured a friends 85...41 3/8 front c to c hole pattern, 41 1/2 rear...basically the same, difference could be tape operator error.
You will also find that the rear spring pack has a center pin that is about 2" forward of center.
