Dumb question... front end
midwest (iowa)
I have here a 1997 80 series that clunks when turning tight circles. I’ve owned several and this is the first that feels like an old farm truck when I turn on pavement. Bind clunk... it looks like someone has been into the transfer case. there has to be a clutch of some sort that could be bad causing this?? I don’t have much experience with the 80 series.
I assume it's not clicking of birfields in the front axle but if that's it try greasing the knuckles first.
Could be the viscous coupler that most of the US 80s have in the transfer case. It can get burned up/etc. and either lock up the transfer full time or possibly cause other oddities. Many folks just remove it, which is easy, and drive without. If your VC has failed and is locked the clunk could be from something else but the VC could be highlighting it. Removing the VC may take the stress off of things if it is indeed burned up.
Read up on the forum for testing ideas and how to remove it.
I should clarify. It’s not a loud audible clunking noise, it is that binding feeling you get when you try to turn with your lockers engaged on dry pavement. Of course this doesn’t have the lockers engaged, just that clunk you feel
Sounds like the VC is locking up in the transfer case which is pretty common on these rigs at this point. My guess is that a likely cause of this, beyond simple age, is running tires of different sizes that cause constant heating of the VC and wear/failure.
Search around on the forum for related discussions and you can probably get a clear sense of your symptoms matching those of other stiff/locked VC sufferers.
When I got this truck, it had four different tires on it LOL literally one of them I think he took off of the grain wagon. I s*** you not. More than likely that’s what caused the issue I don’t even know what a VC is, but I’ll read up.
ha,
My truck too, and I figured I was the only one. Rear right tire was over an inch smaller in diameter and when I tested the rear locker she had a nice steer that way. VC was toast, etc.
VC = Viscous Coupler. Some debate on it but most agree it's not essential and if it's acting up then just pull it and move on. If you know your way around hand tools you can remove it and be back on the road in an hour or so. Have to pull the rear propeller / drive shaft, pop the rear cover off of the transfer case, remove a snap ring, slide the VC off and then put it all back together. About as easy as it get's.
Need a good set of snap ring pliers, a tube of gear oil safe silicone sealer, tools to clean/prep the gasket surface, tools to remove the prop shaft and transfer case cover and oil/catch pan to drain/refill the transfer case.
Given your different tire sizes I'd put money on your VC being the problem at this point.
