Dumb question, but...
New Mexico/Colorado
Can OME N73J and N74Js be used with stock springs? I know it won't be near optimal, but would be an improvement over stock?
I bought the whole OME Heavy 3" kit, but i don't need 3" of lift right now but would still none the less like to improve the handling. I might just wait until next summer till my annual trip to Colorado before lifting (to save GAS). Maybe i should have bought some adjustable coilovers instead :rolleyes: Thanks.
The OME springs and shocks are matched. The OEM springs and shocks are matched. Mixing is not optimum but can be done. The issue with using OME shocks (a tad longer than stock) with OEM springs is that you could unseat a spring at full droop.
If you choose to use longer shocks (e.g. the OME N73) then you should extend brake lines, diff breathers, and sway bars. I would recommend spring retainers too.
-B-
Adj coilovers are for a stock 80 either. I think they they are matched as beowulf stated as well. If you want to help with handling then I seriously doubt you want to lift it either. Just the lift alone isnt going to hurt with that much gas.
Are the J's L's? I always heard the std called 74e, etc and the the longer shocks 74L Never heard of 74J???
I meant N73L not J :rolleyes: I have the L's on with the stock springs for now, might go ahead and put on the J springs tommorow but i will be running 275's for a while with a 3" lift...not my idea of a cool looking rig. Thanks.
The OME "L" shocks are significantly longer than stock... 3" or more, IIRC. You DEFINITELY will need those things that I mentioned in #2 along with lowered bump stops on all 4 corners. I would not recommend running the L-shocks with stock springs.
-B-
I got my OME kit from Man A Fre as well as the extended stainless brake lines. They mentioned that getting the new sway bars wasn't necessary. Are your referring to some kit to change the stock bars? Any recommendations on where to get these parts on the cheap? Thanks again.
:beer:
A true "kit" should have some provision for lowering the factory sway bars; front and rear. The sway bars will hit the drive shaft on compression unless they are lowered or you bump stop the axle to keep them out of the DS.
Slee offroad sells sway bar drop blocks for the front and a bracket for the rear. The blocks are relatively easy to DIY but they are both reasonably priced.
-B-
