dual shock per wheel
Dual shocks are for bling. Almost every rig you see has single shocks and they ride how they are supposed to, because single shocks work at the designed damping coefficient. If you double that, then it won't have the optimal damping rate for your vehicle and will ride like crap, ie: very rough.
And I think that most funtional dual shock setups are pretty much limited to long travel, baja type stuff. Or those, like some in australia, who may spend upteen miles on crazy washboard roads. We probably don't need any of that. If its a matter of want... I'm sure you can find someone who knows how to do it. :)
Correct, a stiffer rate is only good for going fast and when going fast your shock fluid can heat up. Having dual shocks is sort of like having more fluid. However, an adjustable remote reservior shock is much, much better for that application. They use much more fluid and can be tuned to the exact rates you need. They also cost $$$$$.
If the shocks are valved correctly, dual shocks are beneficial. They can each be lighter valved so that the suspension is not overdamped. Now most guys that are serious will run 2.5" shock or bigger to equal 2 2.0 shocks. With that being said, look at ALL the 80's and 105's that have raced and supported during the Dakar and similar rallies and you will see them running dual shocks, some with the bypass feature. And a vehicle does not have to have long travel suspension to qualify for dual shocks. Look at the stock mini and full classes in desert racing who have less than 10" of wheel travel and see how many shocks they are running...
Some very good answers already given in this thread and i would like to add a little if i may ?
If warranted dual shocks do a couple things one they split the job between two shocks vs one and run cooler longer from less valve/fluid friction two if one fails you still have one at half value that is way better than nothing during a race.
Some rules may not allow a larger body single shock,but may allow a dual shocks.
When a shock is overworked it will heat and become less than ideal for the job.
I think anyone should always look at the application before choosing anything that is overkill if not warranted .
What is your application what will you do with your truck ?
Desert race? then you may need dual shocks or even larger Body shocks .
Daily Driver ? you don't need dual shocks or large body race shocks .
We have such Hi quality shocks available here in the U.S. cant see the need for a dual shock on a daily driver/weekend warrior anymore than that you may need duals or large bodys for your aplication.
Frankie...
I love this forum.
