dual battery tray
Medford, Oregon
Has anyone built thier own dual battery tray?, if so could you please post pics. I want to built one for two optima red tops that sit side to side rather than end to end. Thanks
Yup, just did it. I'll try to post pics. Used the stock tray as the base bolted on a piece of steel big enough to hold to orbitals side by side. Pics will tell all. Use 1/8 inch steel as hold downs. Cost <20 in materials to make. FYI, got a V8 and Summitt Al radiator in my rig.
with a F or 2f I dont see how side to side would fit, I had a hard time fitting 2 end to end on my 40.
well then.......yeah it prolly will :)
secretagent said:
sorry, I have a v8 so i think side by side will fit.
Here are some pics. I had to raise the stock tray using a spacer to get it above my Ford shock towers. Then used some cardboard to mock up a tray. cut it out, drilled holes to screw it into the stock tray then used battery tie downs with some 2 inch steel pieces to hold the batteries. I did add several extra braces to increase the strength of the tray support. Worked out great. Good luck.
Good job supporting the tray on the frame. Did you learn the hard way? My brother borrowed my truck while I was in College and my frame support was in the way of the PS conversion he did while he had it. Needless to say, fender mounting tore some stuff up.
