Dual Battery-Step 1
The first step in my Dual Battery install, is to relocate the washer bottle & install the OEM 91-92 battery tray. The lifted 80 no longer fits in my garage. To do the dual batt project in a warm dry place, I am going to have to use the loading bay after work.
Q1-What tools will I need to bring from home to install the 91-92 OEM battery tray. My main concern is several threads have referred to trimming the battery tray to make it fit. Where is the trimming required & what works best. Dremel . . knife . . . hack saw . . . ?
Q2-I used the p/n on several posts and ordered the OEM battery tray. It is just the molded plastic tray (with foam & rubber). Is this all there is to support the weight of the battery?
I used a coping saw. It has a much thinner blade than a hack saw.
Q2-It is just the molded plastic tray (with foam & rubber).
If you ordered from Cruiserdan you would have everything you need; bolts, grommets, hold-down J-clamps, battery retainer, and nuts. I don't know all the part numbers. Maybe George has them on his web site since he did a full documentation on the 2nd battery many years ago.
-B-
I just bought the tray from my local dealership connection. I figured I could get generic J bolts, I got scrap 1 x 1 AL for a tie down, and since I installed an AL tub on the FJ40, I have a OEM bolts out the whazoo.
So if I got the OEM tray & can get a grommet solution, I guess I have it covered.
Thanks -B-
