Dual Battery Setup - Question
Columbia
Website
www.robinolds.com
Ok, so I followed Slee dual Battery setup for the most part and everything seems to work fine.
Except, I was trying to jump start someone off the second battery and I could tell we were getting a charge but he couldn't turn the crank over until I switched batteries.
Any idea of why that is?
Thanks ahead.
Have you ever tried to jump start a off of a vehicle that is not running? It rarely works. The alternator keeps the good battery from dropping it's voltage. If you are jumping a marginally weak battery with a good one it will possibly work but a depleted one would need the help of an alternator.
When you jump start a vehicle the bad battery will suck the juice out of the good one and provide more draw than just the starter and electronics from the dead vehicle normally do. Combine that with jumper cables that can carry less DC current than the battery cables can and you can see why you would need more juice to get it turned over.
SEANANDHIS80 is 100% correct. When jumping a vehicle on the aux. battery of a dual battery system you would need to have them connected in order to do so. If not then the battery doing the jumping needs to have direct current from the alternator. In my particular setup I have everything done a little different with my jumper cable setup but the type of battery I am using has so far allowed me to jump start 8 people so far since I installed it.
Both Batteries are connected...
Do you have a post of how you have your battery setup?
