Dual battery question
Orinda, CA
Any thoughts on using a motorcycle battery as a second battery? Only for emergency starts. Some motorcycle batteries put out 330 amps, which should be enough to get the LC motor started.
My main battery is fairly small relative to the battery tray. Looks like I could squeeze in a motorcycle battery if I tried.
If if fires it up, then why not. The only problem I see is if you need extended cranking.
For a little more $$ though, you can get a full-size battery, make your own auxillary tray, and not worry about it.
