Dual Battery Load Split
South, The Deep
There's probably no one answer to this, but it makes a good lunch time question. Hellroaring recomends running the start function and all toys from a primary battery [deep cycle] and holding the 2nd battery in reserve for starting should the primary position be discharged.
As I was running lines for an interior fuse block this weekend, it was hard not to notice how crowded the DS battery location is in our 94 - and open the second PS tray is. Very tempting to put the deep cycle in the "2nd" location and plan for interior 12V [fridge and toys] and inverter to tie there instead of all back to the strarting battery - more space for fuses. A better risk management path to hold a reserve battery i know - so what are folks running and any "wish that I'd done that" comments?
I think this setup makes more sense. Why buy a battery that's never to be used except in a rare self-jumping situation, and this lack of use will very likely be the reason the battery lets you down in a rare jumping situation. Batteries are designed to be charged and discharged....they're supposed to be used....that's why you buy a second battery.
I run two Yellow Tops and isolate the starting battery from the second "toys" battery. I run all my accs off the second battery, in the passenger side tray, including the winch .
There's some great dual battery info in the FAQ section. I think most of us have deep cycle second batteries, and run our "illegal" loads on the second.
I never use the starter battery power any of my non-stock accessories. My thinking is that it's one my accessories that is more likely to drain a battery when the engine is off, not my stock accessories.
Our Land Cruisers have auto shut off lights so that's really about the only stock accessory can kill the battery, other than interior lights.
But, I have radios, computers, GPS, a fridge and numerous other things that can be accidently left on or sometimes left on, on purpose while the engine is shut down and since my 2nd battery is a deep cycle, I don't worry too much if it drains it.
Whatever you do, must make sure that both batteries are disconnected when the engine is turned off so that you don't end up discharging both.
Here's my set up:
http://www.brian894x4.com/ExpeditionLCEngines.html
For my interior accessories, I just run a single heavy guage wire into the cab to a main central fuse box, which then also feeds a rear fuse box for accessories back there. It keeps it all simple.
Interesting comments. So is there a good path thru the firewall - like the plug on the drivers side - on the PS for a more direct wiring route? I've looked over there on our 94, but nothing jumped out at me.
I like the distribution blocks at the terminals - releives crowding and makes it more manageable to trouble shot, add and subtract accessories. Is that a BlueSea product?
There is a rubber grommet about half way down the firewal on the PS that you can easily get the high gage wire through and you can just reach it without taking the glove box out but easier if you remove it. I ran #4 all the way back to the rear from the second bat under the door sills.
