I have a question, I am setting up dual batteries in my 1985 fj60 with a externally regulated alternator and I have the surepower 4 post 95amp isolator along with all the wires run, except the excitation wire. When I fire the vehicle up with this setup the vehicle is cleary not charging. I do not have a voltmeter at the moment but going off the dash voltmeter its defianlty not charging. Does an fj60 need to use this fourth post and if so does which of the two wires on the back of the alternator does it tie into? Thanks I really appreciate any insight.
) and had no charge upon start up. I have very little voltage drop with my system, less than 0.5v, and have installed many isolator systems in marine applications without problem. The switch like superjuice is using is very simple, however, only the battery that is selected on the switch will charge. So if one battery is dead, and you have to turn the switch to #2 to start, you then have to switch it back to #1 to re-charge the dead battery. If you leave it on both, the alternator can overcharge the good battery while trying to charge up the dead one.
